  • 5 Replies
  • 13469 Views
23pack
If I download a video from one of the cameras, where exactly does it go and how do I access it?
ron-bali
When I use a Windows laptop to aaccess Arlo and download a video it oges into the defualt Download folder used by other applications. To access it, find the Downloads folder and the downloaded file then use a video player (Windows Media Player or VLC).
When I use Android, the downloaded file goes into the Gallery where photos are by default. The vieo will play if you click it in the Gallery app.
5 REPLIES 5
ron-bali
steve_t
Master Master
To your mobile device gallery or to your computer downloads. What are you using to download?
ron-bali
On Android, just using the Arlo app, select a device, then sellect a saved video, then select Download at the bottom.  Similar on Windows
For Android, it goes into the Downloads folder. You should be able to find it in the Photos or Gallery app (or a file manager). For Windows, it goes to wherever you have set the browser to save downloads, the Downloads folder in your profile by default.
23pack
Perfect! We're new to this Arlo system, so I wasn't sure. Thanks to all who responded!
