VMB3000 Arlo Pro Base Station Access USB from iMac
  • 1 Reply
  • 1712 Views
CathDog
Hi there,
I am a bit techy but not very networky, I am wondering is it possible to access the USB External HD (local storage) attached to the Arlo Pro Base Station from my computer (imac)? The camera, base station and router is set up in a standard way, base station attached to my router with the supplied ethernet? cable and camera by wifi.
My achy tired bones and I thank you in advance.
Cath
You can't access any drive on the base over the network. You mustb properly unmount it sand stick it into a computer. I suggest thumb drives since they're easier to handle than a plugged in drive.
