  • 2 Replies
  • 986 Views
cmiles
My base station has died. Need some input on what I should buy to replace and if new cameras are also needed.
Dannybear
What makes you think the base station is faulty? No LEDs showing, look to be offline.
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
See here for compatible base.
https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
FWIW, You must mean a VMB3000.
All bases should support your current cameras (new bases always support all the cameras in the field when released, and you have old cameras).
But you should follow up on @Dannybear's suggest and confirm that it has actually failed.
