VMB4000 - Homekit stopped working, unable to remove basestation
  • 2 Replies
  • 1277 Views
mamcfarlane
I had to do a factory reset on my Arlo VMB4000 base station  today to allow it to communicate with a few Pro cameras.  Got the reset and cameras working but the cameras no longer work in HomeKit.
I thought I would remove the VMB4000 from HomeKit and then add it back, but I get an error when I try to remove the VMB4000 from HomeKit using Arlo Secure: "Arlo Basestation cannot be removed because it is not responsive..."
Any ideas on how to get my cameras working with HomeKit again?
mamcfarlane
Thank you Shane.
After your change I was still unable to remove the HomeKit link using Arlo Secure, but I was able to remove it in HomeKit.  After removing the basestation using the HomeKit iOS app I was able to link the basestation back to HomeKit using Arlo Secure on iOS.
All appears to be working well now.
Thank you again.
ShayneS
Thank you
mamcfarlane
Thank you Shane.
Thank you again.
