Can I use the Arlo Pro camera plugged into the power supply all the time ? The battery only lasts a few days and I have to charge them too often.
Thanks for the help, camera works like champ less the battery and plugged in with a standard charger. The camera is in a high activity area and is always recording must use a lot of juice.
Yes. I have one camera plugged in all of the time and it maintains a 96% charge. If you buy the 4 camera system though, you only get one power brick and cable, and I have not found a way to buy additional Netgear power bricks without buying an extra battery.
Buy an aftermarket 5 volt adapter and micro usb cable (less than $15) take the battery out since it won't charge with the aftermarket adapter.
You don't need the battery in it anyway if you are running it on AC.
Excellent!
