  • 2 Replies
  • 2197 Views
RAG-UAE
I would like to buy like 10 arlo pro cameras .. In my house am using a main router with 5 different APs with different 5 IPs (2 cameras on ech IP ( access point))
so,
Can I use the base station in a router with specific IP (192.168.2.1 ex) with a camera on another IP ( 192.168.5.1) ?
What about the app , do all cameras with be shown in app ? while am in wifi 192.168.2.1 , can i see the cameras on (192.168.5.1) ?
Streak2
Master Master
The cameras talk directly to the base on their own network that gets automatically set up.
You just need to plug the base into an ethernet port on the router of your choice and make sure that you are connected to the same router when you set up the base and the cameras.
If you want a second base on a second network, then same as the above but that will be a separate account and then you grant access between the two accounts. All cameras will then appear in the same app.
Once all set up, it makes no difference what wifi you are connected to in order to view the cameras/recordings etc.
Streak2
Master Master
RAG-UAE
Thank you my dear 💐
