Seven days storage is for the basic ( free) level and tho 1 gb limit is mention ( prob for the suits ) , it is not enforced.
If you think another way, 10 secs is about 1 Mb. That would allow a thousand 10 sec videos.
USB recording is only a backup if the cloud storage goes down for some reason
It's the Arlo servers that delete the files, not the base. I believe that you can fill up whatever device you plug into the USB port which is why the settings allow overwriting when full. I have a 1TB hard drive plugged in and will try to remember to unplug and check it out on the computer.
Just checked the drive and it has all videos recorded from the cameras attached to the base since Oct. 18. There are numbered folders starting at 0000 that each contain 512 videos (not sure why 512 but there ya go). The video names would have to be converted from epoch time just like many of the downloaded videos.
I seem to have a weirdness with my base - not sure if it's normal or not but every time I have to do something with attached hardware (USB drive or cameras) it seems to need to be power cycled. A restart via the Restart button in Settings, My Devices, my base doesn't seem to do it. When I reattached the hard drive, the interface said I needed to reformat the drive. A power cycle simply reconnected the drive. So, I make a hardware change and I power cycle - it's just the way it is.
As I mentioned above, the initial indication was to format the drive but a power cycle cleared that up so I lost nothing. It may be my base, it may be a firmware issue.
That's great news!! That's even better than anyone had thought. Gotta get me a Pro base
