Is the running man on that camera grey or black? Does it turn amber when there is motion detected?
Same issue and running man is gray
Since it's gray, it's disarmed, as mentioned above. You need to check your modes to verify that either the default Armed mode or one of your custom modes is selected.
.that helped!!!
.that helped!!!
