Trying to use Arlo app to sync Arlo Pro but shows "Devices Not Found"
  • 1 Reply
  • 720 Views
Davangcal4477
Trying to use Arlo app to sync to cameras and base. When click find device. Says devices not found. Need help.
You first need to claim the base. Is that what you're trying to do? Is whatever device you're using to set the system up on the same network as your router and base station? What are the LEDs on the base showing - all of them?
