Trying to change time record from till motion stops to 120s timed record. Doesn't save.
  • 1 Reply
  • 1065 Views
Dan74
i'm trying to change time record from record till motion stops or 300s to 120s timed record ..everytime i goto the slider to put it to 120s an hit save then exit the screen it goes back to record till motion stops or 300s is there something else i should be doing i"m starting to get frustrated thanks for any help
JessicaP
Hi Dan74,
Is this happening on the Arlo app on iOS/Android device and/or web client on your computer? Are you trying to edit the time recording through the default "Armed" mode or on a different mode?
