Trying to change time record from till motion stops to 120s timed record. Doesn't save.
i'm trying to change time record from record till motion stops or 300s to 120s timed record ..everytime i goto the slider to put it to 120s an hit save then exit the screen it goes back to record till motion stops or 300s is there something else i should be doing i"m starting to get frustrated thanks for any help
Hi Dan74,
Is this happening on the Arlo app on iOS/Android device and/or web client on your computer? Are you trying to edit the time recording through the default "Armed" mode or on a different mode?
