I have two Arlo Pro installations on two sites (home and summerhouse). IOS App installed
One setup on my own account and one setup on my partners account and when both have given access to each other.
On my own account I cannot control the mode anymore which bacially mean no value of the system.
When I shift to armed it automaticaly shifts to disarmed after approx 30 min unless I am psysical present on that site. Then the mode shifts to armed even if I ask it to be disarmed. All modes have the same mistake, so shifting mode does not help. Is not a geo user or setup error (checked 100 times), and it have worked quite well, but not since July this have been a problem.
Any help would be apprec
Does this mean you're using geofencing or not? Have you tried using the web client to see if that works any better? You can use a mobile browser if set to use the desktop version of the site.
The problems is with all modes
set at armed .... after 30 min.... disarmed
set at geofencing (with armed when not presend) = disarmed after 30 min
When on site with disarmed..... after 30 min.... changes to armed
set at geofencing(with disarmed at present)... after 30 min changes to armed
Like Arlo does not waht me to have two installation due to subscription rules, but they are two installation on two different accounts.
Currently I an testing a custon mode and that one have been udchanged for 60 min now... new record ;-o
