Time associated with video clips are way off. Caught movement at 4:46 PM ET but showing 1:16 AM.
  • 2 Replies
  • 1242 Views
wiznkids
I've had my Arlo Pro cameras for about 3 years and over that time I have replaced batteries at least twice a year. I replaced them yesterday and today I noticed the time associated with the video clips is way off.For example, the camera caught movement at 4:46pm ET. But the camera is saying it caught it at 1:16am.
The times have always been spot on for when they catch and record motion. I cannot seem to find any reference to set the times associated with the system. Any thoughts other than to reset everything?
Reboot the base and check the time zone setting in the base settings under Settings, My Devices, your base.
wiznkids
Thanks for the reply. I found that for some reason the time on the base was some how set to Tehran time!  I changed it and then rebooted...No change. and then rebooted again. I shut the whole system down and will go through the setup mode today to see if that does it.
