System offline
  • 15 Replies
  • 5459 Views
sfcatcher
My LED lights are all green across, but all my cameras are showing offline. System is armed and all cameras were working and now all are off.
sfcatcher
Factory reset seems to have done the trick. Not sure what caused the malfunction but glad to finally have everything back going. Had to reinstall all cameras.
15 REPLIES 15
Have you tried restarting the base?
... as well as both the app and web client?
sfcatcher
I restarted everything multiple times and lights are green across the board. In the Past, if just the Internet was offline, the light would be amber. It’s like the box is saying everything fine but the app saying everything offline.
ShayneS
What do you see over the web browser?
sfcatcher
Idk about web browser, but on the app it says everything appears to be offline. Nothing wrong with Internet as everything in house working normally.
ShayneS
Can you check to see what the web browser says as well.
sfcatcher
What do I need to look at within the web browser? I logged in and nothing really stands out, I tried view cameras and it takes me back to my app which says they’re all offline. At night I’ve noticed that the cameras IR is still activating so I feel like they’re working but there’sa glitch somewhere. Really wish I could get an answer from ARLO..
Try using the browser on a PC, not the mobile device.
@ShayneS is a mod who works for Arlo (Arlo employees all have the Arlo logo next to their user name).
sfcatcher
What am I looking for once I get to a PC and open Arlo in browser? Just log in and then what? Is it Going to do a functional test or something?
Similar stuff to what you see in the app.  @ShayneS is just wanting to check if you see the same status there that you are seeing in the app.
sfcatcher
Everything still shows the same on a PC. Everything shows offline, devices and box. Tried to arm/disarm, won’t do anything.
ShayneS
Hey @sfcatcher
Thank you for verifying that. Are the Status lights on your Base Station still showing all green? As of right now I can see your base is currently offline 10:43AM Pacific time. If your base is showing your status LEDs Green right now, that might imply something is occurring with your base, possibly a Hardware issue.
I'll continue to look in to this for you. Please let me know your results.
sfcatcher
Yes all three lights are green. The one in middle will blink periodically a few times but all are green. Typically if the Internet has gone out one of the lights turns to yellow/amber.
ShayneS
A factory reset may help with this issue. I am not seeing your base station as online on my end.
sfcatcher
