Status light showing camera status
Homer1181,
Log in to your Arlo account and navigate to Settings > My Devices > select your Arlo Pro camera > Camera LED. From here you can toggle on/off the battery charged indicator LED.
While this is a good idea for a possible future development, the camera LED does not currently have any function in relation to the camera being on or off. I encourage you to post your idea in the Arlo Idea Exchange where it can get the best exposure to other users and the Arlo development team.
SmartThings (by Samsung) will do what you want. Well not the led light but what you can do is have a smartthings motion sensor in your room or a open/close sensor on your door, add alro to the smartthings app, then setup a routine that when that motion sensor detects motion or when the open/close sensor opens, maybe during x hours on x days, to turn the arlo camera off. You'll never have to remember if it's on or off again. Smartthings will let you have full automated control of when you want the camera on and when you want it off. Smartthings can also send you a push notification telling you when the camera has been turned on or off. I use it for my 4 interior cameras.
