Was just curious if the arlo pro can be added on the the existing arlo system I have. I have 4 standard battery operated cameras. I can fit upnto 10 cameras. So I clearly can add on. Does it let me do that.
Yes, Arlo Pro Cameras are backwards compatible and will sync to your Arlo Wire-Free base station. Arlo Wire-Free cameras will also sync to your Arlo Pro base station.
