Arlo Pro base station overheating?
  • 2 Replies
  • 4242 Views
patmvcr
my base station keeps shuhtting down.. is it because it is overheating? it is in an enclosed loaction along with a router and phone modem.... they seem warm but the Alro base does not seem to be particularly warM/ Is it very sensitive to overheating?
mbauer
Hello, the Arlo Pro specifications state that the base station can operate at 32° to 122° F (0° to 50° C).
https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-the-features-and-specifications-of-the...
mbauer
What do you mean going off line, what are the front LEDs showing when this happens... Is it power or Internet offline.
But, it may just be a bit close... but an easy test, move it out and away the lenght of the cable and see if the issues continues ( either one )
If it does, I would recommend a full reset of the base and re install the cameras as if new.
If the problem still keeps happening and going off line, then maybe a call to Netgear Support may be in order.
