  • 6 Replies
  • 2585 Views
Brookechook83
I have 4 Arlo pro cameras, 3 of which have solar panels attached. They seem to have been working fine and then recently 2 of the cameras arent charging from the solar panels. Ive disconnected and reconnected the panels and also cleaned them. They get plenty of sun. I just find it interesting that two stopped working around the same time.
6 REPLIES 6
Brookechook83,
Try swapping the working solar panel with one of the other cameras that is not working. Do you still experience the same issue?
Brookechook83
I got the cameras working but the the solar panel on one say “connect a compatible Arlo charger to the device to charge”
they are genuine Arlo solar panels!!!
Check that the cable is solidly connected to the camera.
If it is, then I suggest swapping the camera with one of the others, and see if the problem moves with the camera or stays with the panel.
Brookechook83
I have checked the connection and it’s fine. I put the camera on the working solar panel and it’s fine so definitely the solar panels are the issue.
Are they still under warranty?
Brookechook83
I don’t think so. I’ve had them for quite a while.
