I have three Arlo Pro wireless cameras. And have had them for a while now. I've decided that getting up and down the ladder to charge these will not be feasible in the winter, so I purchased a solar panel. First I purchased an offbrand. It kept taking the camera offline, so I returned it. I tried switching cameras around, switching batteries around, switching locations, resyncing, rebooting. All of this. So I got tired of this and bought an Arlo Solar Panel. Plugged it in, same thing. It's offline again. What am I doing wrong? It shows the camera is charging. I'm getting tired of messing with these things. I spend wayyyyy too much time on this. Seems like this should be a no brainer, but obviously there is an issue. Anyone have a solution?
Try charging your cameras to 100% then put back up and plug the solar panel in as it might be taking the camera offline till a certain charge % is reached.
Offline can be a variety of things such as dead batteries, 2.4GHz interference, weak signal, or just a display issue. It looks like you've tried everything I'd suggest. It may be that the non-Arlo panel did something to the camera - or not. About all you can do now is open a case with support to see what they may ultimately do.
