  • 1 Reply
  • 4497 Views
unlimitedsounds
Luminary
Luminary
Anyone who has the solar panel charger, I have some questions. I just got one yesterday and upon reading it mentions that it is not ment to charge the battery, but to keep it charged? I am not sur what the means? Right now, one of my cameras has a battery at 91%, will the solar panel bring it back to 100% or whatever it can depending on how much sunlight it gets? Also, how fast (or slow) does it take for this thing to show that it has actually done something? I can see where it is showing that it is CHARGING (with the lightning bolt symbol on the battery when there is sunlight).  I just want to be sure its really doing something (for what this thing costs).
Thanks...
ckdxxx
Yes, what they mean is that it's not intended to rapidly charge your camera's battery from 0% to 100% like the plug-in charger- if you started at 0, it'd likely take several days before it was fully charged (but it eventually will get there!). They recommend starting at 100% charge so that the panel only needs to top up the battery based on usage.
ckdxxx
