Solar Panel Power Cord Extension (VMA 4600
  • 1 Reply
  • 1814 Views
Extra
Is there a extension for the power cord from the solar panel (vma4600) to an  arlo pro camera?  The location for the panel is to far away from where the camera needs to be.  I need a longer power coard from the solar panel.
There's no certified extension cord for the solar panels. You can use  another one but then it's up to you to make sure the connections are weathertight. Use of a 3rd prty cord could lead to warranty denial if the issue is caused by the cord and/or improper sealing.
