As usual a new firmware appears to have been messed up! Since the last firmware update non of my cameras are recording when armed. Everything appears normal in the app, as shows cameras, shows schedule, shows armed but yet nothing is getting recorded!! Have tried resetting and resyncing. Saw a post from someone else who said he was giving up with Arlo now who seemed to be having the same difficulty. This is ridiculous Arlo!! New firmware new problem!!!
I dont know if that is what caused my problem but I had a very reliable camera stop working/recording at 9:31am yesterday. Then it started up again after midnight. It seems like they just pick a camera and shut it off on us, just because they can. It has happened once in awhile with no reason with my other 4 cameras.
Since these issues are relatively one-off (it's not happening to a large group of users), the fastest thing to do is to remove everything from Settings, My Devices and start fresh. For whatever reason, it appears that something gets corrupted and the reset fixes it. Be sure to note all settings, modes, rules, etc. to speed the rebuild.
Bit too much of a coincidence that. Clearly a bug and a fix on the quiet me thinks! 👀
That is usually an easy fix to correct quirks.
