Occasionally when I go into the MODE section to ARM/DISARM the cameras, it will show 2 base stations in the MY DEVICES section. I only have 1 base station... does anyone know the reason for this?
The second/lower "base" is the base's siren. It allows you to rename it.
It only appears occasionally and disappears from the screen after approx 1-2 seconds?
I just noticed that you had provided a screenshot so I have now looked at it and can say that isn't what I thought what you were talking about. Sorry.
I've never seen (or, at least, noticed) that before. If it's a bother, I think you'd have to perform the factory reset procedure to clear it up.
