The system runs great, no complaint about that. But need some help setting up the time on and off. Able to up in a srart time of 9 pm and want to stop at 8 am. The 8 am will not take. Any ideas
If you go into your Mode menu and click the symbol to the right of "Schedule" you can set up your schedule. The days run midnight to midnight so you would have to set it up for example
Midnight to 8am - ARMED. 8am-9pm DISARMED. 9pm-midnight ARMED and set that for every day.
Then from the mode menu, select Schedule mode for recording and it will change between ARMED and DISARMED automatically depending on the time. If you use a custom recording mode, use that instead of ARMED
