I am trying to set up a new Arlo Pro system with two cameras. I only get as far as activating the base station. I never get a green light for power, only amber. I never get a green light for an internet connection, just blank. I do get a green light for camera.
The power led should only be Amber during booting....
try a reboot of the base with power button....if the led for power stays Amber, you may have to reset the base(hold in reset for ten sec, till LEDs all flash )
Tried your solutions, same result. I suspect I have a defective base station.
Swap systems at the store or open a case with support using the Contact Support link at the bottom here.
