Sensitivity help!
Just mounted up my cameras. I have them in my driveway and side of house. I have the sensitivity all the way down to 1 and it still notifies me of a car driving down the street about 30 feet away. I don't want a notification every 20 seconds.
Eliminate the section of street that the cams see by changing angle or location
Are you sure your sensitivity setting is saved at 1? If so, as above, you'll need to reconsider your camera position
Yes they are all at 1. I can't really go back any further on the house. 😞
Post screenshots so we can see what you see.
