Security Lights going off when detecting snowflakes. Any way to turn off light?
One of my three security lights keeps detecting snowflakes, so it is going off every second. Is there a way to turn off that light, without removing the device from the app, which I have had to do before to get it to stop. I have moved the sensitivity level to 1, and its still going off constantly. I don't want to have to keep removing the device, then when it stops snowing,
I have to go out and take down the light, remove the battery, and set it up all over again.
Try adding a custom mode for the bridge. Include the two lights that are working properly, but leave out the light that is having the problem. Then you can switch to that mode when the light is misbehaving.
Alternatively you can disarm the bridge from the app - although that would turn off all three lights.
