Is the Cloud Up?
Is the cloud up? I have three cameras that show, on the Devices page, images that were from about 20 minutes ago. Yet the Library page doesn't show any such videos from that time frame. The latest Library video is over an hour old.
No88Fan,
No outages are being reported. Are you able to stream and make manual recordings?
I just made a manual video and photo and they both showed up in my Library right away. But prior to that, the latest video in the Library was 3 hours old when the camera image on the Devices page showed 20m ago. Should that image from 20m ago not have been stored in the Library?
Here is the Arlo system status.
Quite what it tells us is not clear. For example, it does not warn people about any of the known issues that the techies are working on.
Just another user
It's 11/18/2019. Is the cloud still down? I am not getting any notifications and videos are not recording/saving.
Mavila503,
Are you using the default "Armed" mode or a custom mode? Are you able to live stream and manually record?
JamesC,
I typically use the GeoFencing mode as I like it to arm when I am leaving my residence. A lot of the times it will not disarm when I reenter the set zone which is how I found out my cameras stopped recording. Since finding this issue, I have set it to Arm and it doesn't notify or record. I have set a custom mode and it doesn't notify or record. When the lights are off and it is armed, I can see the IR lights turn on as if it is recording however, it doesn't notify or record.
I am able to live stream and manually record.
Mavila503,
Given the troubleshooting steps you've already taken, it seems this issue will require more in-depth investigation. Do you have an open support ticket I can reference/escalate?
@JamesC wrote:
Mavila503,
Arlo's cloud absolutely is having issues. There was a complete outage on 11/18, I was awake when it happened and web, app, everything went dark. Down Detector reflected this with all of the users reporting the outage.
The Arlo status page is useless, it showed "All Good" when literally nothing was accessible to anyone a couple days ago.
Please stop telling people it's their systems that are the problem.
@Phoney49 wrote:
You need to contact support.
https://www.arlo.com/en-us/support/
The cloud has not been down.
You are dead wrong and stop telling people to waste their time contacting Support. I was awake when the outage happened.
Get informed before spouting off bad advice to people here.
No. Case # 41273021, 41273146 and the other are closed.
