  • 14 Replies
  • 5641 Views
  • 6 In Conversation
No88Fan
Is the cloud up? I have three cameras that show, on the Devices page, images that were from about 20 minutes ago. Yet the Library page doesn't show any such videos from that time frame. The latest Library video is over an hour old.
14 REPLIES 14
No88Fan,
No outages are being reported. Are you able to stream and make manual recordings?
No88Fan
I just made a manual video and photo and they both showed up in my Library right away. But prior to that, the latest video in the Library was 3 hours old when the camera image on the Devices page showed 20m ago. Should that image from 20m ago not have been stored in the Library?
Phoney49
Luminary
Luminary
I also had 2 incidents today of one on my dogs detected (Alexa warned me and I looked), but no notification or video saved by Arlo? Maybe they didn't hit the activity Zone??
michaelkenward
Sensei Sensei
Sensei
Here is the Arlo system status.
Quite what it tells us is not clear. For example, it does not warn people about any of the known issues that the techies are working on.
Just another user
Mavila503
It's 11/18/2019. Is the cloud still down? I am not getting any notifications and videos are not recording/saving.
Phoney49
Luminary
Luminary
You need to contact support.
https://www.arlo.com/en-us/support/
The cloud has not been down.
Mavila503
I've already been on the phone with two different techs. They both kept having me pull batteries out, restarting the hub and reinstalling the cameras. Non of this worked. Unfortunately my cameras stopped recording after the 11/7/19 update. Luckily I have Ring cameras covering the exterior of my home. At least they work.
Mavila503,
Are you using the default "Armed" mode or a custom mode? Are you able to live stream and manually record?
Mavila503
JamesC,
I typically use the GeoFencing mode as I like it to arm when I am leaving my residence. A lot of the times it will not disarm when I reenter the set zone which is how I found out my cameras stopped recording. Since finding this issue, I have set it to Arm and it doesn't notify or record. I have set a custom mode and it doesn't notify or record. When the lights are off and it is armed, I can see the IR lights turn on as if it is recording however, it doesn't notify or record.
I am able to live stream and manually record.
Mavila503,
Given the troubleshooting steps you've already taken, it seems this issue will require more in-depth investigation. Do you have an open support ticket I can reference/escalate?
mamarcac
@JamesC wrote:
Mavila503,
Arlo's cloud absolutely is having issues. There was a complete outage on 11/18, I was awake when it happened and web, app, everything went dark. Down Detector reflected this with all of the users reporting the outage.
The Arlo status page is useless, it showed "All Good" when literally nothing was accessible to anyone a couple days ago.
Please stop telling people it's their systems that are the problem.
mamarcac
You are dead wrong and stop telling people to waste their time contacting Support. I was awake when the outage happened.
Get informed before spouting off bad advice to people here.
mamarcac
Mavila503
JamesC,
No. Case # 41273021, 41273146 and the other are closed.
