Second Camera, Keeps Going Offline Arlo PRO
I have 1 camera that i cant keep online, I shows up in my App or PC with the option for LIVE, i click to play and it spins, do it a second time and show off line. Only way i can get get it back online is to physically tap the camera, or remove it and resync it with the base. I have reset the base, restarted the app and doesnt do anything. I have 2 other cameras that have worked perfect. I swapped batterys and locations with working cameras and still get the same trouble.
There is no set timeframe for it to go offline. May go a day or may only go an hour before it happens again. I contacted support and got a replacement camera and still having the same issue. Is it possible i go 2 bad cameras or am i missing something.
Im confused how i have 2 working cameras and continue to have trouble with 1 even with swapping batteries and locations with the working ones.
Contact Netgear Support for possible warranty issue
I had one of my Pro cams that kept going offline about every 1-2 days. Only way to get it back online was remove the battery and then put it back in. I must have been up and down the ladder 20 times. After the run around from Netgear, they confirmed that some batteries cause this. Return it immediately. My 30 day returns passed and Netgear would not honor the warranty because I didn't buy it from an "authorized dealer", no kidding, 45 days old and never worked right. My works fine, plugged in without the battery, and has now been online, without a glitch for 6 days in a row.
I had a similar issue with my 3 camera setup. The same camera would go offline intermittently and I also had issues syncng this particular camera without plugging it into AC power. I think the battery compartment in this camera was to big causing the battery to shift and loose contact with the camera, I tried 3 different batteries and changed location tfrom 50' to about 10' from the base station with no success. Tech support was called and they sent me a replacement in a few days. its been about 3 weeks now and the system is working as expected now with no cameras going offline as it was prior.
