After months of working OK, the Scheduling timer appears to be malfunctioning again. I have a daily schedule set where the system is armed at night and passive (no alerts or emails) during the day. However, all of a sudden, the system is ignoring the schedule and even though it should be disarmed, is still sending alerts.
Anyone else having this issue? I'm suspecting a firmware update might be the issue?
Hi @The_Riddler,
Where did you set up your schedule? Did you set it up on the Arlo app on your phone or on the web client on the computer? Try checking both clients to be sure that the schedule are showing correctly.
I would suggest to try rebooting the Base Station to see if that will helps. Also make sure that your Base Station is on the correct time zone to ensure it is arming/disarming at the right time. You can check this by going to Settings > My Devices > Choose your Base Station > Time Zone.
