Use the Home button, perhaps a couple of times. There's an issue with certain devices and certain OSes that is causing this and use of the Home (or multitask) button usually allows the app to work.
KylieCatterall,
What Android version is the phone running? Are there an OS updates available?
If you check the other threads on this, you'll quickly see that uninstalling and reinstalling it will get you the previous version. The faulty update has been pulled and the previous version reinstated.
Yes, I finally found a helpful thread regarding the issue.
Hopefully, no one reset their device based on this thread.
I don't know where it is now, but the engineers rolled back the app. So the only way for it to work is to uninstall the current app and then redownload and install it from the Play store.
Go to settings>apps. Select the app and tap on Force stop. Now uninstall the app. Again install the app. It will definitely work this time.
Hope this will help you.
Thanks & regards,
