Recording
  • 1 Reply
  • 2391 Views
Missyrobinson
I have 3 cams pointing at different areas of the front of my house. One just for drive way. One for the front yard facing the road and one for just the front door. My issue is if anything triggers the porch cam or the garage cam once the person arrives at my front door or vice versa that cam does not record. How do I get it to record motion from those cams even if another cam is recording?
Default is Armed or all on...
you have to create custom modes that turn on all the cameras.
Such as these rules in one mode
A senses, A records
A senses, B records
A senses, C records
and continue the series...if wanted
b-b
b-c
b-a
c-c
c-a
c-b
make the times and sense level the same...
when you start, it allows one cam rule...so do it and save. Then go back and edit the new mode to add additional rules/ cameras
