Arlo Pro Sensors Doesn't work w/Triple Pane
  • 2 Replies
  • 2714 Views
  • 3 Likes
PamArloPro
I purchased the VMS4230 | Arlo Pro 2 camera system from Best Buy and I just realized the the sensors cannot detect motion through my Triple Payne Low E Argon windows. I have it sitting in my front window and I was wondering why it was not recording anything. I have it at the highest motion setting. The camera works because it records when I move the camera around. Has anyone else had an issue with the Arlo Pro and Triple pane Low E Argon windows?
Streak2
Master Master
The simple answer is that the Pro using PIR based movement detection cant detect the heat changes through glass.
The Arlo Q having pixel based motion detection will work through glass, you just need to turn off night vision to stop the IR leds reflecting off the glass.
Streak2
Master Master
PamArloPro
Thanks! That makes sense.
