  • 4 Replies
  • 3936 Views
dalequayle
Is there a way to control the recording time on Arlo.  It seems to default to 10s, is there a way to adjust that?
As mentioned in the FAQs and many times here, edit your modes. Mode tab, click on your base, edit your modes. All settings are in there. Poke around and experiment. Create your own custom modes and set up the schedule, if desired.
Knight21024
I've changed the time from 10s to the Max 120s but there is no option on the web interface to save this setting.
Knight21024
The Android phone interface has a save but when i select it - it reverts back to 10s.
Does the "public" plan only support 10s?
Knight21024
Ok i solved the problem on the Andriod interface you need to save the setting (upper right click word "Save") and then back on the rules edit dialog do the same again (upper right word "Save")
The web interface doesn't have the "Save" word anywhere on the screen.
