Record sometimes and sometimes not
  • 5 Replies
  • 3272 Views
stribor45
I noticed that camera is not recording sometimes for last month or so.  I thought it might be weather related so I cranked up the sensitivity but that didn’t help. Any other things i can try to resolve this?
5 REPLIES 5
What is the motion sensitivity in your modes and rules? Are you using the schedule? Have you seen the base LEDs showing a loss of connection to the router or servers?
stribor45
@jguerdat sensitivity is set to 90%.
Sorry I should have explained this better. It records when the motion is in some area of the view but not when the motion is in another part of view.  I have set up the view using rectangle to cover pretty much everything camera sees.
ShayneS
Hi @stribor45
It sounds like you are using activity zones. Have you tried to delete & recreate the zone over the web portal?
stribor45
camera is on baterry power so what i do i go under video settings under pan and zoom  this shows me view of the camera and with orange rectangle i create area that will be in the camera view and therefore whatever movement is dedtected in that view it will be recorded.  problem is that nothing is being detected and therefore no videos. I can see gray motion detection icon
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
