Rain Triggers Motion detection regardless of sensitivity
  • 8 Replies
  • 37321 Views
  • 5 Likes
TheFivePack
I just got my Arlo Pro and 3 cameras a few days ago. I've had 2 of 3 setup for days without issue but after installing my 3rd today, it goes off every couple minutes once it started raining. I've changed sensitivity as low as it can go and it still triggers. Basically as soon as the event recording ends (120 seconds) it starts a new one. I had to turn that alert off after a few hours because it was blowing up our phones with notifications. I would understand if it was raining extremely hard but this is crazy. And neither of the other 2 cameras have triggered at all, even with higher sensitivity settings and all 3 are outside and exposed. A friend had to return one of his cameras the motion detection was defective and I'm thinking I have that issue as well. Anyone had this issue?
TheFivePack
You nailed it, rained again and it's the slow drip from the overhang of our deck. The drips are probably 2-3 inches in front of camera. I'm guessing I need to find someway to shelter it from the drips. I'm just not sure how. I can't move the camera as the post it's on is the only spot to get that backside of my house.
8 REPLIES 8
Your the first I've heard of normal weather setting off the camera...  Mine sat in even heavy rain and the only problem was occasionally rain drops on lens
You can pull the battery pack and reset the camera and see if that helps,... Or as you said, it may be a defect causing it to be over sensitive
Drake3287
Luminary
Luminary
I agree, sort of strange the rain would do it. The only weather related issue I've had is the wind blowing the xmas light's near the camera and setting it off. By chance is your camera in direct aim of the rain or is it shelted under an eve or something?
TheFivePack
Drake3287
Luminary
Luminary
Funny how sensitive it can be at times. I've had spiders on the lens and hummingbirds fly by that have set it off.
TheFivePack
Curious, does anyone have a simple solution for this? I feel like I'll have to Macgyver something and it may or may not look good under the overhang of my light wood deck. It rained last night and again I had to turn off my motion detection because it was recording non-stop.
iriesoul
I have the black silicone covers for my pro cameras. One of my cameras it out side mounted on a tree. It has been raining here off and on in cali and have had no problems with the camera being triggered by the rain. Hope that will help.
TheFivePack
Thanks. It has to be the camera. Turned off motion and tried audio, goes off repeatedly with no noise. Moved camera so nowhere near a drip and rain still sets it off. Have another camera on backside of same post and it doesn't trigger at all with same settings. Hopefully the replacement from Amazon will be better.
iriesoul
Yeah might be a bad camera since you have no problems with the other ones. Hopefully your replacement will be better.
