I bougth the base station and a camera Arlo Pro. When I tried to register en netgear account I could with the camera but no with the base station. It appears to be registered by someone else or a representative. When I contact with the Netgear Support they can´t help me. And Amazon answered me that I have to contact with Netgear.... so ?
Someone has the same situation ? What can I do?
monoambiente,
When you create your Arlo account. The device is automatically registered (under the email you used for account creation) on the support site. This is why you're seeing the message stating it has already been registered.
If you would like, I can check to make sure the device is registered correctly by you if you provide me (please use private message) with the email address you used to set up your Arlo account.
A new kit, the base and only one camera.
I don't believe that the online registration has anything to do with warranty coverage. The receipt should be sufficient.
monoambiente,
