Any Help?!
Believe this is a know issue ... other threads too.
Put in a trouble Ticket to Netgear Support.
Look on page ( unknown what device your using ) for SUPPORT, click on that and then again Contact Support
you should see an email, html reply, phone number... your choice.
On my Iphone 7 Plus I can speak over wifi but the volume is very low. If I switch to my Mac and use a Chrome browser, the volume is much higher. I have it set to 100%, so I'm not convinced that it's working correctly on the Iphone, even when on wifi.
More interesting thing is: I cannot use microphone with tmo lte, but my sister can use it with Verizon lte. What wrong ?
I have tested this using a T-Mobile iPhone 6S and have not been able to duplicate the issue being described on LTE.
For those experiencing this issue:
-Does this happen intermittently or are you always experiencing this when using LTE?
-What is the quality of the LTE when you see this behavior (cell signal)?
Chicago312,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
