Push Notifications Not Working On Android
-Colton
First if your not getting pushes , I would uninstall and reinstall the app.
fyi, pushes come at the start of an alert while emails come when the video file is completed.
There are no SMS alerts sent unless many use their phone number as email addresses like many cell providers allow.
I would go in and add your phone number to the email adresses to see how it works for you..with Verizon it's pretty good other carriers not so much
Colton4444 wrote:
I've already tried uninstalling and reinstalling the app. Restarted my phone, etc. I don't know how to add my phone number to my email address though I've been looking up how to do it. Btw I go through straight talk as my service provider. Also if I were to add my number to email does that mean all future emails will come in as text messages? Because that would be a lot, or can I specifically choose which emails I receive as sms such as only arlo?
First...to add an email address, go to MODE.
If ARMED ( more than likely your using this one ) doesn't appear on the right column , click on the Base unit.
Click on ">" after ARMED to edit, Pick camera ( this must be done for each ), hit edit
Near bottom below your current email. to add email hit the circle with + in it
Make entry and hit SAVE
It will only send SMS for that arlo email , not all of them... and you can easily remove later
Straight talk uses verizon or att , you should know
format for cells number to SMS is as follows;
