Push notifcation take up 1 minute to 17 Minute after camera trigger . it be better have have the notifcation push instantly camera triggers, there a serous bug on push notifcation server need to be fixed
Hi @pcuser12345
Have you tried to remove & reinstall the Arlo Mobile App on your device? Do you have the latest firmware version installed on your phone?
yes i unstall reinstall the app and factory reset the base station no result it’s same as before
i all ready contract them here the Case # 40710887 have test the push notifications, all notifications are working fine almost all app except arlo isn’t push notifications it’s delayed about 1 minutes to 17 minutes after it recorded video it should push instantly once it’s triggered
it’s both Mobile Data & Wifi
notifications take longer after video recordings push out take up 1 minutes to 20 minutes randomly instantly
push notifications does t work well it push 17 minutes after camera trigger
What are the speeds from your internet provider? When the 17 minute delay occurs, is your device connected to the wifi?
What Device/Model/OS are you experiencing this issue with?
When did this first occur?
any status’s notifications fix
I'm on the same page. Cameras without "smart" notify instantly. Cameras with """smart""" take 10+ minutes to notify of anything. That on top of cameras set to people notifications only notifying of any motion. And columns and nearby animals being recognized as people.
My cameras are on 1Gbps fiber, delays occur on Wifi and LTE, so certainly something on the server processing the smarts. Really frustrating, unfortunately I already spent too much building my arlo system to just walk away now.
