I just bought my 6th camera, does this mean that I now have to begin paying to use them?
"It depends." (TM)
If you have a second base you can create a new account using a different email address and set up the new system and associated cameras in that account. Then use Settings, Grant Access from one account to the other. Once the procedure is completed, all selected cameras will show in one login.
If one or more of your cameras are Q, Baby or Go, you could move them to the second account while leaving the wireless cameras on the single base.
Otherwise, yes, you'll need to upgrade your subscription.
