I have a problem With my Arlo Pro cameras. They ar reccording movments of birds inn my yard, but not cars and People, when they should. Why is that?
It is not allways that problem, the cameras don't work only when they should.
The camera is i ouside waching the front of my house an frontyard.
The range for people with the Pro is max at about 24ft , ... I recommend to not try and cover an area larger than the detection zone from the camera.
Cars/roadway should be eliminated and then the sense level ( check FAQs ) can be slowly adjusted higher till response is good.
Thank you for the answer.
The camera is not as far as 8 ft away and birds are beeing detected further away than 8 ft.
I can try to turn up the sensetivity.
