Pro camera and VMB4000 Base Station not recording to cloud. Able to do motion detection test.
  • 1 Reply
  • 1146 Views
airprtlts
Ok, so the cameras will show video and will record but only when I manually direct them to record.  The cameras will not initiate recording from motion detection.  I can do a motion detection test and I get the yellow light, but when I put the system into armed mode, they will not record.  I have restarted each camera, I have reset the base station and I have changed the batteries.  I do not know what else to do.  None of my devices will take an update.
Base station VMB4000r3   Firmware 1.16.1.1_3885_9330458
Cameras
H15   Firmware 1.092.0.29_57_8bc7ce9
H7    Firmware 1.4.293
Dannybear
Check the camera rules under the Armed mode are set to detect motion and record if not done already.
Alternatively create a custom mode and add rules to see if that works better.
