Pro 2 Camera Solid Blue when plugged in for 3 seconds then nothing. Not a battery issue.
Basically the battery died, I have since replaced the battery in that camera, but the camera no longer registers / initiates. Add a battery and the light goes blue for a few seconds then goes off and nothing. Plug it in and the light flashes for a couple of seconds then stops and nothing.
Anyone with a solution / help? Its not a battery issue.
C
What happens if you try to sync it? If nothing happens, use the Contact Support link at the bottom here.
