Possible to buy a replacement cable connecting the solar panel to Arlo Pro camera?
Hi there....
Does anyone know if it's possible to buy a replacement cable connecting the solar panel to Arlo Pro camera.
Regards
That cable is permanently connected to the panel, right? Thus a new cable can't be sourced. You can try using the Contact Support link at the bottom here to see if they can help.
Hi there....
The cable does actually unplug from both the solar panel and the camera so it's not permanently connected...
Use the Contact Support link at the bottom here to see if they will help.
