  • 1103 Views
COOPE1P
Hi there....
Does anyone know if it's possible to buy a replacement cable connecting the solar panel to Arlo Pro camera.
Regards
That cable is permanently connected to the panel, right? Thus a new cable can't be sourced. You can try using the Contact Support link at the bottom here to see if they can help.
COOPE1P
Hi there....
The cable does actually unplug from both the solar panel and the camera so it's not permanently connected...
Use the Contact Support link at the bottom here to see if they will help.
