Has anyone experienced pixelating video in the first 2-3 seconds of the recorded video. It happens every time for me. It has great reception full Wifi bars... and does not happen with my original Arlo camera.. just with the new Pro.
Awesome news!! Hopefully we all get that firmware update soon!!
Pretty crazy that a few of us that have been reporting on this from the beginning, haven't been offered this firmware....
I hve the same issue. Pixelated video with stuttering on both local recording and cloud based. I have a fast upload speed (just speed tested at 40+mbps). Pretty dissapointed so far, invested a reasonable amunt of $'s on the back of positive reviews.
Fingers crossed a firmware update can fix the issues.
Just been advised by customer service that the firmware update is only for Arlo Pro cameras with the new base, not Pro cameras on the original base!
No sign yet of any solution to my problem.
Have been offered a replacement Pro camera but told it will most likely still exhibit the same problem as my existing Pro camera!
Gutted by this news.
I dont, they pushed out another beta last week and it was actually worse, no pixelation anymore but now lag.
I'm thinking they will have this fixed in 6 months after they release the Arlo Pro XXX model.. ![]()
https://arlo.netgear.com/hmsweb/users/library/share/link/EF98A842EDEA558B_201706
here's a manual recording i just made... the camera was the furthest from my base station, and was only showing to bars signal, so i moved my base station, using an ethernet over a/c ... it's now almost the closest and has full signal, and still pixellates and stutters.
Howie411 wrote:
I'm running a beta firmware from Netgear on my Arlo Pro and (knock on wood) it has fixed the pixelation issue. Its been about 2 weeks now. 1.092.0.4_12662 is what I am running. Required a lot of esclation (to corporate level) to get someone to help me.
Hopefully this firmware or an even better one is released soon!
After a number of months of suffering with the pixellation and stuttering problem, Netgear have updated my camera firmware with a 'Field Trial' version (1.092.0.4_13099) and it certainly seems to have solved the pixellation issue. There is an occasional slight stutter but nowhere near as bad as it used to be.
Just keeping my fingers crossed that this will be a permanent fix and things don't deteriorate (can't see why they should).
It would be good if this firmware was released globally and then we'll be able to see how effective it's been for all users.
Yep, 1.092.0.4_13099 is the latest beta software for Arlo. So far so good for me with it running.
Sounds like things are good for you guys - to bad us common folk are still getting pixelation for the past half a year.. @JamesC thanks for all the updates during this process - ..crickets..
Hi.
I raised a ticket, went through all the testing and changes they suggested, provided example videos showing the problems and generally politely complained until they added me to the list of users to be provided with the field trial firmware.
Here is link to the Arlo Beta Test Team - http://bit.ly/2dW5UPe - fingers crossed to see if this works..
