Pixelated and vertical lines video on all cameras starting 3/4/2021. WiFi is working fine.
I've had had an Arlo base station and 2 Arlo Pro cameras for nearly 4 years, and they have always worked fairly well. Staring 2 days ago (3/4/21) I am not getting motion recording when I should, and both cameras are routinely recording shortened video with pixelation and vertical lines. I don't know if this is due to a firmware update or service update with Netgear. My WiFi network is working fine. Since it's on both cameras, I think the cameras themselves can be ruled out (unless this is caused by a firmware update). Any light on resolving this issue would be appreciated. I have already tried resetting the cameras and the base station to no avail.
You can always check when updates are done by looking in the Firmware Release Notes section here. The latest release was the middle of February so it's likely not a firmware update that caused this. Try moving the base away from the router as much as possible - I had to do this a while ago after having it almost touching the router for years.
Came here searching for possible solutions for why 3 of my 5 cameras that had been working fine for several years stopped detecting motion about a week ago. Initially I tried removing and re-adding the cameras which did not solve the issue. I then removed the batteries for a bit and this did not solve the issue.
I then tried jguerdat's advice to remove the base station away from my router and BINGO. That worked!!
