  • 1 Reply
  • 3618 Views
Klemske13
All,
We are using the Arlos for our business and need to mount a couple outside but dont want to just use the magnet or security mount.
What we need is a dome/shell that can be screwed into the exterior. I know the cameras are weatherproof, it isnt because of that. We want a dome so the camera isnt messed with or if it is, just the dome is and it would also give a more professional security look.
From searching around on amazon and google, i am not seeing anything. Anyone know of what that is made for it, or can be made to work with them?
Thanks!
Problem with an enclosed mount ( like a dome ) and the Arlo cameras...
The cams use IR to detect motion... Glass def blocks IR, so no motion would not be seen... some plastics can do the same.
They are made to be very weather resisant and sit out side, best bet still is using a quality camera mount with locking screws.
But if willing to think outside the box, someone recently had pics of a shield they use ...it was a part of like a catchers mask...wire grid to protect the camera from vandals
